Is there a setting somewhere to tell xnview how to sort files in a directory (ie, by date modified, alphabetic, etc)? I've looked through the options several times and can't find it. I thought maybe it went by whatever the folder was set to in windows, but it currently sorts them by modified regardless of windows settings. (It should be noted though that at one point it was sorting them by name, I have no idea what changed or how.)
In case it makes a difference, I'm talking about when you go next/previous while in viewer mode, not anything with browser mode.
Order of files in directory?
Drahken
Re: Order of files in directory?
In View/Arrange byDrahken wrote:Is there a setting somewhere to tell xnview how to sort files in a directory (ie, by date modified, alphabetic, etc)? I've looked through the options several times and can't find it. I thought maybe it went by whatever the folder was set to in windows, but it currently sorts them by modified regardless of windows settings. (It should be noted though that at one point it was sorting them by name, I have no idea what changed or how.)
Drahken
foxyshadis
Drahken
Requested…
—> Drahken
Hello !
• AFAIR, the sorting commands in View mode have been requested, I need them too there,
but I guess that Pierre forgot this “trivial” detail…
KR
