But sometimes they do not appear, sometimes its just a grey box where they should be and sometimes they appear perfectly correct.
B5: Imagetab arrows do not show
Troken
Don't know if anybody already started a thread about this, but if you have many images open at the same time so that there is not enough room on the screen for the tabs, it appears two arrows in the top right corner (makes it able to scroll through the images).
Re: B5: Imagetab arrows do not show
Yes, a known bug but don't understand why there is a problem with tab controlTroken wrote:Don't know if anybody already started a thread about this, but if you have many images open at the same time so that there is not enough room on the screen for the tabs, it appears two arrows in the top right corner (makes it able to scroll through the images).
Olivier_G
I also have this bug. I noticed the following:
- Sometimes, arrows overlap tab, like this (on the right edge):
- Arrows disappear only when I add a new window while arrows are already shown (ie: adding the window that "create" arrows doesn't reproduce the bug).
=> isn't it just a focus/hide issue due to overlapping areas?
Olivier
Olivier_G
Troken
I can not reproduce this in 1.90 (final). Is the bug gone?Olivier_G wrote:Previous method to show the bug = fixed with Beta 6.
But there is still an issue when you:
- add 3 windows after appearance of arrows
- use left arrow to show back first window
- then close a window in the middle, with its tab
=> arrows will disappear.
marsh
Yes. Closing middle tab no longer causes arrows to disappear. Overall, tab arrows are improved over previous version.Troken wrote:I can not reproduce this in 1.90 (final). Is the bug gone?Olivier_G wrote:Previous method to show the bug = fixed with Beta 6.
Olivier_G
