RC1: Favourites "\" problems?
marsh
Post by marsh »
There is a problem with the handling of the backslash "\" character in new favourites panel.
These problems seem to occur more often in B6, less often in RC1.
Favourites deleted 2 at time.
I always use folder path for filename. If bookmarks contain or end with "\", sometimes 2 favourites entries are delete instead of 1.
"D:\k\_keep\g\L\"*"D:\k\_keep\g\L\"
"D:\k\_keep\g\W\"*"D:\k\_keep\g\W\"
Null string (square character)
Sometimes an odd square character appears. Delete with tree view menu, restart program, and it reappears.
I was renaming folders similar to this "T:\TTT\T\", deleted them, when I first saw square character.
Re: RC1: Favourites "\" problems?
marsh wrote:There is a problem with the handling of the backslash "" character in new favourites panel.
I always use folder path for filename. If bookmarks contain or end with "", sometimes 2 favourites entries are delete instead of 1.
"D:\k\_keep\g\L"*"D:\k\_keep\g\L"
"D:\k\_keep\g\W"*"D:\k\_keep\g\W"
I was renaming folders similar to this "T:\TTT\T", deleted them, when I first saw square character.
Sorry but i don't udnerstand, could you tell me a way to reproduce it?
marsh
Post by marsh »
If this used as a bookmark, deleting first entry will automatically delete second entry also.
"C:\in\test\"*"C:\in\test\"
"C:\in\test\1\"*"C:\in\test\1\"
"C:\in\test\2\"*"C:\in\test\2\"
"C:\in\test\3\"*"C:\in\test\3\"
marsh wrote:If this used as a bookmark, deleting first entry will automatically delete second entry also.
"C:\in\test"*"C:\in\test"
"C:\in\test\1"*"C:\in\test\1"
"C:\in\test\2"*"C:\in\test\2"
"C:\in\test\3"*"C:\in\test\3"
Can't confirm. You delete the first entry with menu in favorite pane?
marsh
Post by marsh »
I used <del> key in favourite pane.
If i use del key to delete first entry, only this one is deleted, can't reproduce...
Do you have the problem with a clean ini?
marsh
Post by marsh »
xnview wrote:
marsh wrote:
xnview wrote: Can't confirm. You delete the first entry with menu in favorite pane?
Yes, in layout #3. Perhaps only with preview pane disabled. So there would only be favourites on the left and file list on the right.
With no changes to clean INI, I don't see it.
marsh
Post by marsh »
Fixed in RC2.
