I've installed the AWD-file plug-in and now XnView can view and read AWD-files, which is great. But everytime I click on the thumb an error message appears:
__________________________________
AWD to TIFF converter
Error converting AWD to TIFF.
[OK]
Funny that even though the message appears, I can read the file and all. Is it a bug or is the plug-in not working properly?
XnView 1.90 <x>
AWD-files support (Artweaver)?
Troken
Re: AWD-files support (Artweaver)?
You have only this message when you click on a thumb? And you have not it when you load the file?Troken wrote:I've installed the AWD-file plug-in and now XnView can view and read AWD-files, which is great. But everytime I click on the thumb an error message appears:
[OK]
Troken
Yes, I have it both when selecting and loading it (single + doubleclick). It also appears when I open a folder with AWD image in it. Or when I save in a different format. It seems that it shows everytime I do anything with the image. But apart from that, it works fine and I can view, open and edit. Its just annoyingxnview wrote:You have only this message when you click on a thumb? And you have not it when you load the file?
Oh ok, but AWD plugin is not for Artweaver, so you can remove Xawd.dllTroken wrote:Yes, I have it both when selecting and loading it (single + doubleclick). It also appears when I open a folder with AWD image in it. Or when I save in a different format. It seems that it shows everytime I do anything with the image. But apart from that, it works fine and I can view, open and edit. Its just annoyingxnview wrote:You have only this message when you click on a thumb? And you have not it when you load the file?
Troken
Troken
Drahken
Heh, I was about to post about this issue. Clearly the issue is a conflict between the awd.usr plugin from artweaver and the xawd.dll plugin.
While we're on the subject, anyone know what format artweaver's ad files actually are, or if they're a purely custom format? I'm guessing they're a variation on tiff, but they could be almost any lossless or near lossless format. (The filesize is far too massive to be any lossy format.)
Troken
Troken
Um, this is not important really, but a new question grew: why don't XnView support Artweaver (.awd) files? Sure, there is a working plug-in at the Artweaver website, but couldn't it be implemented?
(I noticed that a certain other popular imagesofteware - beginning with "I" - supports Artweaver in the latest version)
BTW: The conflicting Xawd.dll seems to be gone in RC2, so the awd-plugin works nicely now.
