XnView ShellEx v1.0.0.1 Improvements
ckit
Post by ckit »
I have two Shell extensions which handle pictures installed now, "Context Viewer 1.41e" and XnView's new one. However, there are two things missing from XnView's...
1. The thumbnail is way too small
2. Clicking on the picture does not launch IrfanView the way "Context Viewer" does.
Unfortunately, Context Viewer is no longer available for download but I do have a copy :)
Re: XnView ShellEx v1.0.0.1 Improvements
ckit wrote:I have two Shell extensions which handle pictures installed now, "Context Viewer 1.41e" and XnView's new one. However, there are two things missing from XnView's...
Which size would be better?
Irfanview????
ckit
Post by ckit »
Ok, my Context Viewer's default setting for picture preview is 320x240 so I guess thats the biggest you could make it without the menu looking really weird.
xnview wrote:
ckit wrote:2. Clicking on the picture does not launch IrfanView the way "Context Viewer" does.
Irfanview????
IrfanView (http://www.irfanview.com) still remains my primary image viewer. I still have concerns about making XnView my primary image viewer. When I say "primary" I mean my files associated with that app. Bit by bit XnView is getting better :)
I've updated the shell extension. Could you try again?
http://www.xzeos.fr/download/xnview/XnShellEx.exe
ckit
Post by ckit »
OK, version 1.1.0.0 now launches XnView as it's default action which is great. Now all we need to work on is the size of the thumbnail/picture preview.
Thanks is looking better and better.
Lostclown
Post by Lostclown »
ckit wrote:1. The thumbnail is way too small
Nice picture!
I can see why you prefer the bigger tumbnail :)
Lostclown
ckit wrote:OK, version 1.1.0.0 now launches XnView as it's default action which is great. Now all we need to work on is the size of the thumbnail/picture preview.
You can take a look at:
http://newsgroup.xnview.com/viewtopic.php?p=4246#4246
ckit
Post by ckit »
Thanks, I'll have to try it later. Right now I have v1.1.0.0 locked in memory and I can't uninstall it without a reboot which I can't do cause I'm running a dial-in server.
ckit wrote:Thanks, I'll have to try it later. Right now I have v1.1.0.0 locked in memory and I can't uninstall it without a reboot which I can't do cause I'm running a dial-in server.
You can logout your session too
ckit
Post by ckit »
Ok, this is wonderful!!!
One last request, merge all three submenus into one or two. At least the Thumbnails and Languages should be merged into an Options menu.
ckit wrote:Ok, this is wonderful!!!
Ok ;-)
