thumbnail orientation
Evds
Post by Evds »
In preview and fullscreen the orientation of the photo is correct. The thumbnail however has a different (wrong) orientation.
In RC1 these thumbs are displayed correctly.
V 1.90 RC2
Re: RC2: thumbnail orientation
Evds wrote:In preview and fullscreen the orientation of the photo is correct. The thumbnail however has a different (wrong) orientation.
For which format?
Evds
Post by Evds »
It's a jpeg which has been rotated (jpeg lossless ..).
Evds wrote:It's a jpeg which has been rotated (jpeg lossless ..).
With lossless rotation in 1.90?
If RC1 displays thumbnails properly and RC2 not, this is strange. This might be a problem in RC2, but this could be also a matter of caching. In your RC1 version, could you please delete the whole cache (Tools > Options > Browser > Thumbnail > Cache in RC1 and see whether the problem still does not occur in RC1?
And could you please have a look at FAQ How to rotate images automatically and double-check that the embedded thumbnail is oriented properly.
Evds
Post by Evds »
I have send a test photo to Pierre and he replied that the problem is indeed a bad oriented embedded thumbnail.
I have disabled the option to use embedded thumbnails and then both RC1 and RC2 show a correct oriented thumbnail. If i switch the option back on then RC1 shows a correct oriented thumbnail and RC2 an incorrect oriented thumbnail (i always deleted the whole cache).
Evds wrote:I have send a test photo to Pierre and he replied that the problem is indeed a bad oriented embedded thumbnail.
Good to know.
Evds wrote:I have disabled the option to use embedded thumbnails and then both RC1 and RC2 show a correct oriented thumbnail. If i switch the option back on then RC1 shows a correct oriented thumbnail and RC2 an incorrect oriented thumbnail (i always deleted the whole cache).
Still a different orientation in RC1 and RC2? That's strange and sounds like a bug. :o
