RC2: blue channel is missing in histogram
maix
Post by maix »
I've installed the new XnView-win-RC2.exe, looked at the new histogram feature and did't find a "blue" channel - is it not implemented?
I cannot confirm: When viewing JPG images in the preview and the histogram I can see the blue channel. Which image type do you use? Could you place a sample screenshot of your image preview and the histogram?
Blue is blue…
—> maix
:) Hello !
• Same than helmut, I can see the blue channel in all usual images types I tested…
:mrgreen: KR
maix
Post by maix »
How could I place an image here? Maybe I could sent a small image via mail?
I just see a green, a red and a composite luminance channel but no blue channel with all images.[/img]
Drahken
Post by Drahken »
You can upload it to a site like http://imageshack.us then grab the "direct link to image" and post it here using the img tag.
Click quote on this post if you want to see how I did it.
marsh
Post by marsh »
Confirmed. I'm not seeing blue histogram info on my jpegs at the moment. I'll try to narrow problem down further.
maix
Post by maix »
Here is the image:
[img]http://img261.imageshack.us/img261/9493/histo16nx.jpg[/img]
Upper image: Canon DPP with RGB histogram
Lower right: DPP preview with luminance histogram
Lower left: Xnview
@Drahken: thanx for explanation![/img]
marsh
Post by marsh »
The installer version is different from zip version (which probably doesn't have problem).
Drahken
Post by Drahken »
Using zip version here (didn't even realise there was an installer available, not that i would have used it anyway), and histogram works fine (after I found where the friggin thing was).
EDIT: It's confirmed, the problem is with the installer version. Viewing the exact same image in both the zip package and the installer package, he blue shows in the zip one's histogram, but is absent in the installed one's.
http://allspark.net/cypherswipe/histo-zip.jpg
http://allspark.net/cypherswipe/histo-install.jpg
EDIT #2: I was just looking closer at those pics, and the installer says rc3 (which I didn't think was available yet). The good one is beta 6, but I checked it with the zip file of RC2 as well, and that is also fine. It would appear that this bug was introduced in rc3.
ZIP only here
:) Hello !
• Indeed I use only the ZIP versions always… I've four versions installed, and don't wish to see one overwritten !
—> maix
• Aside : Please untick the box “Disable BB-code in this message” when typing, and then the marker'll work,
no more need to copy¦paste in the address-bar of my browser ! :wink:
:mrgreen: KR
marsh
Post by marsh »
Fixed. RC3.
