viewing TIF problem
kartola
viewing TIF problem
Post by kartola »
Hi
when i open tif image (fax multipage) XnView open it with incorrect proportion... it's like it open the image like a A4 page landscape while the fax it's a portrait A4...
i see the image stretched large and short, while in other programs like the image viewer of windows i see the correct image...
thx for help...
Re: viewing TIF problem
kartola wrote:Hi
thx for help...
Do you have option/view/Adjust zoom...
kartola
Post by kartola »
Thank you very much!
I would never have found it myself!!!
This option checked can give collateral effects?
thx
Olivier_G
Post by Olivier_G »
Just a reminder to say that I believe this setting should be permanently ON (and its option removed), as explained here.
(Pierre: I meant to ALWAYS apply this 'Adjust zoom'... not the contrary as you seem to have understood)
Olivier
kartola
Post by kartola »
I agree, at least checked by default...
thx
