How to save the window configuration
Rolf Wiegand
Post by Rolf Wiegand »
I am just beginning to use the new version 1.90. When I size the tree-window, the dataset-window, an the preview-window, these settings are not saved on exiting the program. Whenever I start xnview, the tree-window and the dataset-window are minimized an I have to resize them.
How can I save my configuration of the windows?
Thanks for help.
Rolf Wiegand
Re: How to save the window configuration
Rolf Wiegand wrote:Hello,
Strange, all pane are saved for me, do you use an old xnview.ini?
Post by Guest »
I am having the same problem. I did an uninstall of the 1.82 version before I installed the 1.90 version, and I use the .ini to save.
Try with a clean .ini?
Killua
Post by Killua »
Well, I also fact this problem...
And Save in Registry...
And if you clean registry of xnview settings??
Post by Guest »
xnview wrote:
Anonymous wrote:
xnview wrote: Strange, all pane are saved for me, do you use an old xnview.ini?
That worked. :) I renamed the old .ini to .saf and saved a new .ini after I created all the settings... it saved the window positions just fine. :) Thanks for a great program!
Rolf Wiegand
Works after deletion of xnview.ini
after deletion of the xnview.ini the window configuration is saved. But this solution is not very satisfying. I spent some time to set all options to what I want them to be. Now I have to remeber all my settings and do the changes again.
Is there a possibility to migrate the changes from xnview 1.84.2 to 1.90?
Thanks for your help.
Rolf Wiegand
Re: Works after deletion of xnview.ini
Could you send me your xnview.ini to check the problem?
pwoz
Post by pwoz »
i'm reading this thread with interest.
If it can be of any use I can send my xnview.ini, I have the same problem... :)
@ pwoz:
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?t=11741]Screen layout not remembered.[/url]) wrote:Ok, MaximizeXnviewAtStartup=1 seems to be the problem!!!
Try to delete this line...
Rolf Wiegand ([url=http://newsgroup.xnview.com/viewtopic.php?t=11811]solved[/url]) wrote:Hi Pierre,
as you advised me, I removed MaximizeXnviewAtStartup from the .ini and now it works fine.
Post by Guest »
thanx!
But I think something is going wrong...
I opened xnview.ini, deleted the line with Maximize etc etc... , saved, opened xnview, changed something (just to see if it works), closed, then re-opened, and It did not worked. It's like the first time I've opened it and also the xnview.ini has again (very strange :!: ) the line deleted just seconds before...
I cannot understand what is wrong. :|
Remade !
—> Guest
:) Hello !
• I've commented the line with a semi-colon “;”, but after I restarted¦closed XnView,
the line has been remade @ another location in the file !
• So, there is a hitch…
:mrgreen: Kind regards, Claude
Pwoz
Post by Pwoz »
same thing for me...
No results with deleting or commenting the line.
(and the commented line as Clo said, pops out uncommented in another location inside the same file)
Pwoz wrote:same thing for me...
So please send me your xnview.ini
