Use Folder.jpg as folder thumbnail image
SimesB
Post by SimesB »
Following on from this thread:
http://newsgroup.xnview.com/viewtopic.php?t=11735
I would really really like to be able to control what image the folder uses as a thumbnail image, could we have an option to make XnView do what Windows Explorer does in that if there's an image in the folder called Folder.jpg it uses that as the folder thumbnail image?
Cheers,
Simon.
Re: Use Folder.jpg as folder thumbnail image
SimesB wrote:Hi,
Could you try to disabled thumbnail column in option/File list/Folder?
SimesB
Post by SimesB »
Hi there,
Sorry I don't understand what you mean? I want the folders to show in thumbnail view, disabling that option means I can't see them. It would be good to be able to choose what image is used.
Simon.
SimesB wrote:Sorry I don't understand what you mean? I want the folders to show in thumbnail view, disabling that option means I can't see them. It would be good to be able to choose what image is used.
Sorry try to uncheck Folder in Option/File list for 'Show as thumbnails'
SimesB
Post by SimesB »
If I do that it doesn't show any images on the folder thumbnail.
SimesB wrote:If I do that it doesn't show any images on the folder thumbnail.
Ok, i'll check...
Olivier_G
Post by Olivier_G »
xnview wrote:Sorry try to uncheck Folder in Option/File list for 'Show as thumbnails'
I don't understand why unchecking this option would allow to display a specific image for the folder... :?
Instead, XnView should check whether there is an image called "folder.jpg" in the folder and use it in priority to any other image(s) (including '4 in 1')... when 'Show as thumbnails' is checked, of course.
Olivier
SimesB
Post by SimesB »
Olivier_G - yes that's what I'm after, it would be great if XnView did this!
Simon.
SimesB wrote:Olivier_G - yes that's what I'm after, it would be great if XnView did this!
Simon.
Try the 1.90.2 :-)
SimesB
Post by SimesB »
That's awesome! Just what I wanted. Thank you so much.
Simon.
