1.90.2 (on W2K): Last character missing from "comment&q
HWK
Post by HWK »
Dear Pierre,
we (at the German Literature Archiv at Marbach) are going to start a huge scanning project to convert the library's paper catalogue.
In this project, important metadata is written to the tiff tag 270(dez), "Image Description" of every scan (file format is grayscale tiffs, LZW compressed).
We are rather new to XnView, but soon began to love its ability to show this tag as "comment" in the "Thumbnails & Detail" view when evaluating test scans.
Unfortunately, the last character seems to be missing from this "comment", regardless of its length.
Using other tools like Ulead TIFF Tag Editor or tiffinfo we can confirm for example the tiff tag reads
Datei=0136_0002_1.tif; Kette=44622; Kartentyp=SY; KFarbe=weiss; Barcode=1
while XnView only shows as "comment"
The truncation only occurs to tiff files of this kind, the comment of jpg files for example is perfectly complete.
Regards,
Heinz Werner Kramski
Re: 1.90.2 (on W2K): Last character missing from "comme
HWK wrote: Unfortunately, the last character seems to be missing from this "comment", regardless of its length.
Could you send me a sample, please?
hwk
Sample files
Post by hwk »
Pierre,
thank you for stepping in.
Find two sample files as
http://www.dla-marbach.de/fileadmin/_te ... 0002_1.tif and http://www.dla-marbach.de/fileadmin/_te ... 0005_1.tif.
Regards,
Heinz
Re: Sample files
hwk wrote:Pierre,
Ok, i'll fix it in a 1.90.3
Nope
:arrow: Pierre
:) Hello !
• With the HWK's sample <0136_0002_1.tiff>, I get an error message with the 1.90.test. Same than the Paul's issue, and here :
"Bad LZW codes", but I guess it's because the TIFF contains meta-data…
- I works with 1.82.4, though…
:mrgreen: KR
HWK
Post by HWK »
This is fixed in 1.90.3 now, thanks a lot!
Heinz
