XnView Skins
Adi K.
XnView Skins
Post by Adi K. »
Hello everybody!
I find that the info.txt-file for skins should be completely documented and the bitmaps described. I read the whole thread which I think is the most informative:
http://newsgroup.xnview.com/viewtopic.php?t=968
But it's obvious that it's out of date...
I recommend that Pierre finally unleashes the secrets of info.txt to clarify skinning questions.
Regards,
Adi
PS: It's nice that it's possible to post unregistered to this forum.
Re: XnView Skins
Ok :-P
version = 2 (current version to use all bitmaps)
browser32 = 1 => browser32.bmp (on Xp/Vista)
auto = 1 => create hot and disable icon
tabtree = 1 => tree.bmp (icons in tab for tree, and for categories/rating)
icninfo = 1 => info1.bmp & info2.bmp (icons on thumbnails & categories/rating)
imbar = 1 => jpgbar.bmp (used in jpeg lossless dialog)
Not secret
:) Hello !
• Not quite updated yet, but better than nothing, please have a look HERE ;)
• Now, the small browser tool-bar has 11 icons, and we can add also extra-bitmaps for the Categories etc.
• You could get a clue from the skins-pack of mine that is available HERE.
- Especially, please see the Mus_Musculus skin about its <info.txt> file,
and also the browser tool-bar and the extra bitmaps it contains, all is up to date…
:mrgreen: Kind regards,
Note : It's better to sign up ! :D
Mistake !
:arrow: Pierre
:) Hello Pierre !
• Wrong, since with "2", you can't display the two extra-icons of the browser tool-bar Next and Previous folder…
- To get this, one needs "version = 3"
{Punishment : I give you 100 lines… :D }
:mrgreen: KR
JohnFredC
Re: Mistake !
Post by JohnFredC »
Clo wrote: display the two extra-icons of the browser tool-bar Next and Previous folder… To get this, one needs "version = 3"
How to display those buttons? I use Mezich.
(Hi Clo)
John
Patch it
—> JohnFredC
:) Hello John !
• The “Mezich” skin is outdated about the browser tool-bar.
- For a test, you could add two simple 16*16 motives enlarging that bitmap, @ the right side from the "Filter" icon :
—> [Filter][Previous][Next]
• Indeed, set version = 3 like I said above.
• You could also give a glance in my pack, jus to see the template I quoted ;)
:mrgreen: FR
JohnFredC
Post by JohnFredC »
Ah... got it!
Thanks Clo.
John
