Vista and tags
majalid
Vista and tags
Can I search and organize pictures by keyword tags that I added using Windows Vista? Thanks
"To the royal guards of this realm, we are all victims in-waiting."
Re: Vista and tags
I'm not sure that vista write tags in IPTC, but in a private dbmajalid wrote:Can I search and organize pictures by keyword tags that I added using Windows Vista? Thanks
majalid
majalid
XMP can't be removed withouth removing EXIF. I don't want to loose EXIF. (Edit> Metadata> Clean> EXIF/XMP)xnview wrote:With Clean dialog, you can remove XMPmajalid wrote:Can I remove XMP metadata without removing EXIF metadata? I would like to copy XMP keywords to IPTC. Vista write tags in XMP but it can also read IPTC keywords.
Ok, i'll add EXIF and/or XMPmajalid wrote:XMP can't be removed withouth removing EXIF. I don't want to loose EXIF. (Edit> Metadata> Clean> EXIF/XMP)xnview wrote:With Clean dialog, you can remove XMPmajalid wrote:Can I remove XMP metadata without removing EXIF metadata? I would like to copy XMP keywords to IPTC. Vista write tags in XMP but it can also read IPTC keywords.
majalid
Cool! You made my day!xnview wrote:Ok, i'll add EXIF and/or XMPmajalid wrote:XMP can't be removed withouth removing EXIF. I don't want to loose EXIF. (Edit> Metadata> Clean> EXIF/XMP)xnview wrote: With Clean dialog, you can remove XMP
