TIFF 16-Bit look very dark in Vista
Cumulo
Post by Cumulo »
im using 1.90.2 in vista 64 bit, but all my pictures in TIFF-16bit looks like very dark. On Media Center, Photogalery, Irfanview etc, all TIFF's look like great.
Any Ideas to solve this Problem?
Greets,
Cumulo
Re: TIFF 16-Bit look very dark in Vista
Cumulo wrote:Hello,
Could you send me a sample?
Cumulo
Post by Cumulo »
xnview wrote:
Cumulo wrote:Hello,
sure, but the size ist 36.3 MB for this 16bit-TIFF.
You could get im from this Adress:
http://www.gleitsegelwetter.de/CRW_5552.tiff
It's a Canon EOS 10D RAW-File, converted with DCRAW 8.60 from Dave Coffin. The converted File hat sRGB ICC-Profile included.
Greetz,
Stefan
Cumulo wrote:
xnview wrote:
Cumulo wrote:Hello,
Greetz,
Stefan
Strange, i have no difference between xnview and other software...
Cumulo
Post by Cumulo »
xnview wrote:
Cumulo wrote:
xnview wrote: Could you send me a sample?
Greetz,
Stefan
looks the Picture on your Screen also very dark?
See here the difference:
Greetz,
Stefan
Cumulo wrote: looks the Picture on your Screen also very dark?
You have the problem only on vista??
Cumulo
Post by Cumulo »
yes, only on Vista x64. I get changed my OS last Month. Before, i am using XP SP2 with xnview (all versions) without any problems. At moment, i don't have a XP Machine there. Can only test on Vista.
What do you think. Could this be a Problem by extract in dcraw with RAW to TIFF?
Greetz,
Stefan
And the tiff is correctly readed in other software (not embedded viewer)?
Cumulo
Post by Cumulo »
xnview wrote:
Cumulo wrote:
xnview wrote: You have the problem only on vista??
yes. Look there in Digital Photo Pro 2.2 from Canon.
Cumulo
Post by Cumulo »
Cumulo wrote:
xnview wrote:
Cumulo wrote: Hi,
i found out, that dcraw extract RAW to TIFF with embed GAMMA. I think, xnview coudn't read Gamma Value of my TIIF's and takes it 1.00 and that's the reason why my Pics look like very dark?
dcraw say's in command syntax:
-4 Write 16-bit linear instead of 8-bit with gamma
The Problem ist, dcraw can not extract RAW directly to TIFF without Gamma.
Greetz,
Stefan
