For saving my JPEG images I use a high quality setting to preserve the image quality delivered by the camera.
But for certain applications (e.g. sending images per email) I store them with reduced quality by using the options dialog of the Save function.
Unfortunately I forget much to often to reset the JPEG option to high quality again, and then I store my high quality images with low quality, overwriting the possibly only existing copy of them.
Could the settings from the "Tools" -> "Options" menu dialog be made persistent, and option settings (any option) from the "Save" or "Save as..." dialogs be only temporary?
Persistent Options Settings
