Could someone elaborate on how the actual RAW conversion is done as it seems rather quick. I'm used to S7RAW to convert my .RAF files. I understand that the functionality is difference, but the speed remains quite fast. How does the conversion actually differ from "other programs"? What is it you (presumably) do not do?
RAW Conversion, how is it done? (technically)
GulDukat
Hi!
Take the time to appreciate the nature around you.
Re: RAW Conversion, how is it done? (technically)
If you use 'preview', the embedded jpeg will be readed...GulDukat wrote:Hi!
GulDukat
