XnView always bombs when I try to stop the thumbnail Cache
[email protected]
Post by [email protected] »
I have 50,000 JPEGs, MPEGS, and WMVs in 86 folders.
XNVIEW starts doing something when I enter a directory. Probably Caching. This interferes with switching directories because XNVIEW becomes slow to respond to mouse clicks. This is not the bug, it is just annoying.
The bug is that I cant turn off the caching, and then save the settings. Whenever I close XNVIEW, after I turn off the caching, it bombs.
I am running XP, SP2. I have unclicked all the options in Thumbnails but that doesnt work.
Re: XnView always bombs when I try to stop the thumbnail Cac
[email protected] wrote:I have 50,000 JPEGs, MPEGS, and WMVs in 86 folders.
It's perhaps the creation of movie thumbnail, try to disable video for thumbnail in Option/Filelist
Hum, i think that there is a file that crash XnView, try to go in an empty folder before to change the settings!
lairdwh
That fixed it...Good...but
Post by lairdwh »
I tried closing it after disabling caching on an empty folder. It DIDNT BOMB.
Good. Thanks.
But which movie version causes it to bomb? I have the factory default settings.
Re: That fixed it...Good...but
<joke>
lairdwh wrote:I have the factory default settings.
Perhaps you have downloaded a version of the danish XnView factory, not the french one... ;-)
</joke>
