Autosuffix in scanned filenames
Ralex
Post by Ralex »
Hi!
I think it's a good idea to save the scanned images with the autoincrement suffix in filenames without manual setup of first suffix. XnView can't scan existing files in current folder to proceed first filename in batch scan, isn't it?
Re: Autosuffix in scanned filenames
Ralex wrote:Hi!
Yes, i'll fix that
Post by Guest »
xnview wrote:
Ralex wrote:Hi!
Yes, i'll fix that
I'll look forward to this feature!!!
I think the most flexible and "real" solution would be supporting placeholders in filename. See suggestion "Batch scanning: Standard placeholders in filename".
Ralex
Post by Ralex »
helmut wrote:I think the most flexible and "real" solution would be supporting placeholders in filename. See suggestion "Batch scanning: Standard placeholders in filename".
Yes, i think it's usefull too. Placeholder would be more flexible.
