resolution in properties window wrong
Steve
Post by Steve »
There seems to me to be a problem with the resolution given under properties, image information. If I open a jpg which I can see is 180 dpi in the exif (straight from my camera), I get a resolution of ??? x ???
I have version 1.91, on Windows XP, using French language settings
Re: resolution in properties window wrong
Steve wrote:There seems to me to be a problem with the resolution given under properties, image information. If I open a jpg which I can see is 180 dpi in the exif (straight from my camera), I get a resolution of ??? x ???
Do you have enabled option/general/Use EXIF DPI?
steve
Post by steve »
No, this is not ticked
steve wrote:No, this is not ticked
Enable it
steve
Post by steve »
I have enabled it, quit xnview, and then looked at the image - still ???x???
Any ideas?
steve wrote:I have enabled it, quit xnview, and then looked at the image - still ???x???
Any ideas?
Could you post the file, please?
