Buggy tool tip in details mode
Jota.Ce
Post by Jota.Ce »
I have this options for displaying tool tips over files:
<Filename>, <Size> bytes, <Modified>
<Width>x<Height>, <BPP> bits por pixel
<Format>
In this example, i think that's not important.
The thing is that if i set View->Thumnails, correct tool tip is shown. Even if i then set details mode ("lista" in spanish), it works.
But... if i:
1/ Set View->List (i mean detailed list, not column list)
2/ Close XnView
3/ Open XnView
4/ Bring an image tool tip
Then i get this kind of tool tip:
 ,  bytes,
 x ,  bits por pixel
I think those variables are set to "" until you set View->Thumbnails (another options may also wrok correctly)
Thanks, and keep on working that good.
Re: Buggy toop tip in details mode
I can't reproduce this bug...
Post by Guest »
Thanks for your attention, Pierre.
The fact with this bug is that... i never get the correct tooltip, since i always have the "View->List (detailed)" option enabled.
I discovered some time ago that it works correctly in thumbnail mode (and other modes i think). And it works correctly if you change between that modes.
In my previous post, i wanted to mean i use detailed mode always, so if i don't make changes in that configuration i never get the correct tool tip.
I'm using Spanish language, but i don't think that's important in this issue.
I insist, i think the key of the problem is starting XnView with detailed mode, NOT changing between modes.
I can send you my INI file and a snapshot if you want.
And.. i forgot to tell you that i found this bug since the first version i tried (maybe v1.84). It's not a new bug.
Thangas again and best regards.
marsh
Post by marsh »
Try enabling option... browser>file list>[misc]>Scan file headers in folders- 'always'. There is a default tooltip which is shown when the file isn't scanned (thumbnails mode always scans files).
Post by Guest »
Thanks again for taking your time with this.
I've tried that (i had the "Exclude Diskett/CD/DVD" option enabled), but it works the same way.
I maybe have to send INI/Snapshot to Pierre to make him believe me xD
Regards to everybody.
Anonymous wrote:I insist, i think the key of the problem is starting XnView with detailed mode, NOT changing between modes.
Confirmed for XnView v1.91 & v1.91.1 on Windows 2000. (Scan file headers in folders is set to Always.)
My settings for Show tooltips:
<Filename>
<Format>
<Width>x<Height>x<BPP> · <Size>
<Modified>
View As = Thumbnails » Tooltips during scan:
image.jpg, 1234567 bytes, 30.02.2007 20:07
View As = Thumbnails » Tooltips after completed scan:
JPEG TrueColor (v1.2)
1024x768x24 · 1.234.567
30/Feb/2007 20:07:30
Tooltips with View As set to Details:
xx · 1.234.567
See also topic 1.91: Wrong Tooltip
Post by Guest »
XnTriq wrote:Tooltips with View As set to Details:
xx · 1.234.567
I don't even get filename, size and date.
But if you also have problems with tool tip, then it's not only me.
Can't confirm even if i start in details mode. Are you sure that you have the 1.91.1??
Please send me your xnview.ini?
Post by Guest »
INI has been sent.
Thanks again.
Anonymous wrote:INI has been sent.
Thanks again.
Where? Not received it
Post by Guest »
To the address i found on xnview.org: webmaster (at) xnview (dot) com.
but i fogot to delete the prefix "mailto:"
This kind of things happen when you want to make things quickly, but i'm ashamed ¬¬ xDDDDDDDDDDDD
I hope this time work.
Anonymous wrote:To the address i found on xnview.org: webmaster (at) xnview (dot) com.
Ok, with your ini, i can reproduce it
Post by Guest »
Solved in 1.91.2
Thanks for your great work, Pierre. Keep on working that hard.
Dreamer
Post by Dreamer »
Closed.
Dreamer
