Webshots Collections
David
Post by David »
I have some .wbc files that I want to convert for use. They were files created from the Webshots software several years ago, but no longer work with Webshots. I was referred by FilExt.com.
Can you help?
Read
—> David
:) Hello ! Welcome aboard !
• AFAIK, the *.wbc files are supported at reading only currently…
- Maybe the Author could make them readable and writable later, whether the documentation is obtainable. :?
:mrgreen: Kind regards,
Welcome to the forum, David. A search for "wbc" leads to topic Webshots file support. With description in topic "Does XnView support graphic format .xyz?" you can find out about the formats supported by XnView.
Note: Please search the forum a bit first before posting, see topic Rules and Guidelines, thank you.
Drahken
Post by Drahken »
If you want to convert them for use in newer webshots software, you'll probably have to convert to JPG and then use the webshots software to make the JPGs back into a useable webshots file. Although, I think you'd be better off dumping the websahots software altogether, and using some other slideshow screensaver and/or wallpaper changer, one that uses standard formats like JPG and PNG.
foxyshadis
Post by foxyshadis »
Something along the lines of WBC2JPG then? Leaving it out of xnview is by far the smart move, or webshots' lawyers will by coming after the site; not a good idea. Take a look at the home page for the program above: It's replaced by a takedown notice.
Drahken
Post by Drahken »
I know that xnview can open and convert from webshots wbz format, don't know about any other ones (only webshots stuff I've ever used is wallpapers downloaded from their site, and converted with xnview into normal JPGs).
