Thumbnails won't update when file timestamps are changed....
ghost zero
Post by ghost zero »
Thumbnails won't update when file timestamps are changed. Thumbnails only update when image dimensions are changed. Can this be fixed?
Re: Thumbnails won't update when images are changed....
ghost zero wrote:Thumbnails won't update when images are changed. Thumbnails only update when image dimensions are changed. Can this be fixed?
How to reproduce this bug?
ghost zero
- make an image in paint and save it
- youll see the thumbnail in xnview
- now make changes to the image such as scribbling and save
- youll see xnview doesn't update the thumbnail for the changes
CameronD
Post by CameronD »
I cannot reproduce this. Is your change big enough to show up in the thumbnail?
I tried with paint and Photoshop and the thumbnail was updated every time (TIFFs and BMPs - no compression).
Simplest test is just to flip the image horizontally. That way you know it is a big change in a thumbnail.
ghost zero
- i made a small .bmp file with ms paint
- generate thumbnail in xnview
- now draw a big dot in that .bmp file and save
- xnview doesn't generate a new thumbnail
ghost zero
still not fixed in 1.91.3...
ghost zero wrote:still not fixed in 1.91.3...
I can't reproduce it
ghost zero
how about try my ini and see if you can reproduce it...
http://www.sendspace.com/file/xpum7b
ghost zero
still not fixed in 1.91.4 :(
