1.91.1: Resize/Canvas glitch
TheWip
Post by TheWip »
I noticed a small glitch using Image-Resize and Image-Canvas functions with version 1.91.1.
It may be linked to the following issue but I'm not sure: http://newsgroup.xnview.com/viewtopic.php?t=4522
Selecting a 16:10 size from the Standard Size list sets strange values to the Width and Height fields.
e.g. original image size is 1920x1200 and selected size is 1440x900 then new values are
--> in pixels: width = 27648 and height = 17280 :shock:
--> in percent: width = 1440 and height = 1440
It only happens for 16:10 standard sizes: 1280x800, 1440x900, 1680x1050, 1920x1200 and 2560x1600.
But as I said it's a very small glitch since there is a quick and easy workaround... setting the fields myself! :wink:
Re: 1.91.1: Resize/Canvas glitch
Right, i'll fix it
