Passport Photo Option
budz45
Post by budz45 »
With combing the 'contact sheet' feature add more options for creating passport strips form single headhsot images taken
add input fields and some existing advanced features on the 'contact sheet' for predeifned regional sizes such as
USA/Canada - 2.00 cm x 2.00 cm
UK - 3.50 cm x 4.50 cm
European Union - 3.50 cm x 4.50 cm
Brazil - 5.00 cm x 7.00 cm
http://www.epassportphoto.com/blog/imag ... oster5.JPG
The fixed sizes should be exact and also can be edittable upon any regional changes
With previews before creating the page strip, you can call all of this 'passport mode' - just an idea as it would suit Xnview without manually having to rezise images and so on..
http://www.onthegosoft.com/passport_photo.htm
Re: Passport Photo Option
budz45 wrote:With combing the 'contact sheet' feature add more options for creating passport strips form single headhsot images taken
add input fields on the 'contact sheet' for predeifned regional sizes such as
You want only the size (in cm) of the final picture, right?
budz45
Post by budz45 »
Yeah - but in the similar way that this program here can do it ----> http://www.onthegosoft.com/passport_photo.htm
You see the link, can Xnview include a plugin or maybe a new featrure like that, it would be quite cool, thanks author
budz45
Post by budz45 »
I still support the feature to be introduced but in the future:
This is a mediocre mock up of what I mean
This is a screenshot of the application called Passport Photo by onthegosoft
http://www.myupload.dk/showfile/2414124ca56.jpg
jaqian
Post by jaqian »
This would be a very handy feature.
budz45
Post by budz45 »
I think it could be an option within 'create strip of images'
oops66
Post by oops66 »
I strongly support this kind functionality too, so +1
XnViewMP Linux X64 - Debian - X64
budz45
Post by budz45 »
I know this is an old topic :)
..But was just recently thinking.
In the more far future, for XnViewMP, in viewer (under tools), still a "Passport Photo" feature could exist and would work as a feature similar to a future 'Create strip of images' in future MP
Under 'Tools' menu.
Also this feature be better named as 'Wallet Photo'? ...to give it some uniqueness in XnView.
