can't display Original Size with press "*"
heisekaidangku
notice can't found rapi.dll
but I put rapi.dll in the D:\XnView
can't either
can't either
oops66
Re: can't display Original Size with press "*"
It's strange, witch xnview and windows version do you have ?heisekaidangku wrote:notice can't found rapi.dll
can't either
Is the "/" keybord key (fit to screen ) works for you, or it's only the hotkey "*" original size ?
heisekaidangku
OS winXp/Vistaoops66 wrote:It's strange, witch xnview and windows version do you have ?heisekaidangku wrote:notice can't found rapi.dll
can't either
Xnview 1.91.3
only the hotkey
I don't know why?
oops66
I don't know why too, but if any hotkeys works, maybe you have a problem of windows configuration or virus or malwares ????
or try the xnview setup.install ( not the zip file) because usualy xnview is installed here by default:
C:\Program Files\XnView
and not here
D:\XnView
and not here
D:\XnView
Dreamer
Just a remark
—> oops66
Hello !
• Just a remark : Under Vista, it's certainly much better to install any soft like D:\XnView
rather than in the damned “Program Files”, which has access restrictions the hell !
• For example, the author of Total Commander has restored that kind of location in the root because a mountain of issues
when installing¦running¦updating the programme…
- Just my 0.10 €…
KR
OT : Please, check PM.
- Just my 0.10 €…
heisekaidangku
This problem from 1.91.2, I used zip file.oops66 wrote:I don't know why too, but if any hotkeys works, maybe you have a problem of windows configuration or virus or malwares ????
and not here
D:\XnView
heisekaidangku
heisekaidangku
Re: Just a remark
Xnview is a green soft.location should not the reasonClo wrote:—> oops66
Hello !
- Just my 0.10 €…
KR
ckit
heisekaidangku
oops66
Re: Just a remark
--> Clo and ckit
Thank you for your information
