[1.19.4] Browser forgets "Show files in subfolders"
eyebex
Post by eyebex »
When choosing "Show files in subfolders" once, images are correctly recursively listed. But when you look at the "View" menu again, there is no checkmark next to "Show files in subfolders", although that is the current mode. This also has the undesired side effect, that when opening a single file and goign back to the browser, the browsers points to the directory where the viewed file is located. IMHO, if "Show files in subfolders" is enabled, the browser should point to the directory where it was before opening the file and "Show files in subfolders" should still be marked as enabled in the "View" menu.
Re: [1.19.4] Browser forgets "Show files in subfolders&
eyebex wrote:When choosing "Show files in subfolders" once, images are correctly recursively listed. But when you look at the "View" menu again, there is no checkmark next to "Show files in subfolders", although that is the current mode. This also has the undesired side effect, that when opening a single file and goign back to the browser, the browsers points to the directory where the viewed file is located. IMHO, if "Show files in subfolders" is enabled, the browser should point to the directory where it was before opening the file and "Show files in subfolders" should still be marked as enabled in the "View" menu.
Yes, it's by design, this setting is not kept when you change the folder...
eyebex
Post by eyebex »
Hmm, okay, so I'm turning my bug report into a feature request. Would it be a big issue to change that behavior? Would it make sense to you to change that?
GeorgD
Post by GeorgD »
xnview wrote:
eyebex wrote:When choosing "Show files in subfolders" once, images are correctly recursively listed. ... when opening a single file and goign back to the browser, the browsers points to the directory where the viewed file is located.
Pierre, eyebex wrote abour 2 cases; I cited only the one when I look at the current pic in detail - I expect browse mode to stay in its state as no action with folders is done. It is very cumbersome to always go again to the desired folder and re-activate "Show files in subfolders" after each (!) view at a picture... is that also by design? Why this design?
See also http://newsgroup.xnview.com/viewtopic.php?f=34&t=16133
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
GeorgD
Re: [1.19.4] Browser forgets "Show files in subfolders"
Post by GeorgD »
bump :) in 1.97 still cumbersome
So 'Show files in subfolder' saved in .ini or not?
GeorgD
Post by GeorgD »
xnview wrote:So 'Show files in subfolder' saved in .ini or not?
Oops, misunderstanding - I don't care about persisting the mode across closing & restarting XnView (what .ini does), but I care to persist pit within one browsing session: Turn on "subfolders", double click an image to see it bigger, then return to browser and now you're in the directory containing the image instead of where you've been before (more upwards in the path). Please have again a closer look to the posts above, thank you :-)
GeorgD
Post by GeorgD »
bump - still the same in v1.98.8
