I have problems in print-custom interface :
The 1st print is correct ,but the follow aren't in right dimensions.
I write 12x8 cm , for example, and photo on paper is 8x5.
Impossible to control.
Regards.
Print-custom problem
Re: Print-custom problem
Which version do you use? All picture have the same pixels size?cataratta wrote:Hi,
Regards.
version 1.91.4
same photo.
(however I set dimension in cm in out , no depending from pixel)
There is also another strange issue :
for some tiff files the preview on print panel is right then the print on paper is flipped vertical and orizontal!!!Crazy.
I must flip the image befor the print for have correct on paper.
Regards
same photo.
Regards
- Forum Librarian
cataratta wrote:There is also another strange issue :
Regards
- TIFF images with TIFFTAG_ORIENTATION not displayed correctly
- print fax cover (MIRROR)
- Impression Inversée d'images TIFF
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?t=13494]Prints Inverted[/url]) wrote:It's a known bug, will be fixed in 1.91.5arovelstad wrote:Whenever I print a file that is fine in the viewer it comes out vertically flipped, i.e., mirrored about a horizontal line. Other users here have this problem with only some printers. For me it's all of the printers I have tried. If I flip the view vertically, it prints fine. Is there a setting somewhere I need to reverse?
