Slide show: 'Add folder' does not add psd files
difo.pol
Post by difo.pol »
Verzeichnis hinzufügen:
Es werden nicht alle Grafikdateien hinzugefügt. (z.B. keine Photoshop-dateien *.PSD)
ckit
Post by ckit »
In English:
"Small bug in slide show
Add folder:
Not all graphic files are added (e.g. no Photoshop files *.PSD)"
ckit
Post by ckit »
I have two PSD files in a folder with some other JPEG's and PNG's and they get added when setting up a slideshow so I can't confirm this bug.
I could reproduce the problem:
In the slide show dialog, I've added a folder which contains a .psd file using the "Add folder..." button. The psd file was not added.
@difo.pol: Ich hoffe du kannst Englisch lesen/schreiben. Falls nicht, dann poste kurz hier.
helmut wrote:I could reproduce the problem:
Ok, i'll add .psd too
In the slide show dialog, I've added a folder which contains a .psd file using the "Add folder..." button. The psd file was not added. ...
Shouldn't all formats specified in "Options > Formats" be supported here?
ckit
Post by ckit »
Ok, adding a folder instead of just selecting files and I can reproduce the problem too.
Lostclown
Post by Lostclown »
helmut wrote:Shouldn't all formats specified in "Options > Formats" be supported here?
I would think so.
So this should probably be considered a small bug as difo.pol suggests rather than a feature addition as you might think from reading Pierre's reply.
But it doesn't really matter does it :)
Although it might be interesting to know if there are possibly other formats that have this behavior.
Regards,
Lostclown
No, i add only the most used format, else you'll have non picture file
difo.pol
Kleiner Bug in Diashow [German]
Post by difo.pol »
First: Sorry for posting in German. I recognized too late that this is an english spoken forum.
Is there a patch for using the feature to put *PSD-File to the slide show?
Re: Kleiner Bug in Diashow [German]
difo.pol wrote:First: Sorry for posting in German. I recognized too late that this is an english spoken forum.
No problem. Since you speak English, too, I've edited the subject.
Normally, patches are only provided for serious bugs, so I guess you have to wait till the next official release.
xnview wrote:
helmut wrote:...
Currently, all a bit less common file types are not added when using 'Add folder'. I think XnView should know which file types are images, which are sounds, and which are videos. As a consequence, XnView should exactly know which files to add in the slide show. This should not be just the most common ones (+ PSD).
helmut wrote:
xnview wrote:
helmut wrote:...
I can't, because i don't try to read the file, so i can't know if it's a real picture.
