Rename Based on Date
geralds34
Post by geralds34 »
I am using the rename function, to sequentially rename photos based on date. I'd like the sequence number to be based on time the shot was taken.
Is there a function for that, or do I sort based on EXIF date?
Re: Rename Based on Date
geralds34 wrote:I am using the rename function, to sequentially rename photos based on date. I'd like the sequence number to be based on time the shot was taken.
You can use EXIF date in the template (or with menu)
geralds34
Post by geralds34 »
I have been able to rename some files.
I have to run the batch rename function for each day, but frequently get an error, just saying "Error renaming the file".
If I reboot the PC, sometimes I am able to then rename.
geralds34 wrote:I have been able to rename some files.
You get error? Which template do you use?
geralds34
Post by geralds34 »
I tried another renamer (cam2pc) , and also got am error, so I think it might be my system. It has been powered down for a month while on vacation, so maybe virus scanning and updates.
If I get the error again, I will open another thread, so as to not send you on a wild goose chase.
ptupper
Rename error
Post by ptupper »
I have run into that when I go through several iterations of renaming and accidentally have one number sequence overlap another... but once the numbers are organized the error goes away.
