1.91.6 crashes when opened (Vista 64-bit)
jwalker46
Post by jwalker46 »
I removed the prior version, then did a clean install of 1.91.6; as soon as the program is opened, it freezes, and a pop-up window declares "XnView for Windows has stopped working."
Many thanks for any suggestions.
The details are here:
Problem signature:
Problem Event Name: APPCRASH
Application Name: xnview.exe
Application Version: 1.91.0.0
Application Timestamp: 47185b34
Fault Module Name: StackHash_8d13
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 00000000
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1033
Additional Information 1: 8d13
Additional Information 2: cdca9b1d21d12b77d84f02df48e34311
Additional Information 3: 8d13
Additional Information 4: cdca9b1d21d12b77d84f02df48e34311
Re: 1.91.6 crashes when opened (Vista 64-bit)
jwalker46 wrote:I removed the prior version, then did a clean install of 1.91.6; as soon as the program is opened, it freezes, and a pop-up window declares "XnView for Windows has stopped working."
If you drag&drop a picture file on the xnview icon, it works?
Post by Guest »
[/quote]If you drag&drop a picture file on the xnview icon, it works?[/quote]
Yes, it works. (Thank you!)
Is there any way to get the program to open normally (by clicking on the icon)?
Anonymous wrote:Is there any way to get the program to open normally (by clicking on the icon)?
When xnview start, open the browser. Next time, xnview will start in this folder.
jwalker46
Post by jwalker46 »
[/quote]When xnview start, open the browser. Next time, xnview will start in this folder.[/quote]
Thank you very much for your help....and for XnView !!
