Drop down menu empty
pic_viewer
Post by pic_viewer »
I use Windows XP style for the menu. When I click on any entry, like File or Edit, the drop down menu rolls down and presents the sub-entries. If I click a second time the same the list vanishes. So far so right. Now if I click a third time on the same entry, the menu opens again as expected, but is empty. From here on it stays empty until you open a different drop down menu.
Hmm, strange behaviour which I cannot confirm, here. Which XnView version are you using? Which Windows platform do you use (XP, 2000, ...)?
pic_viewer
Windows XP Home, XnView 1.91.6 german. The problem does not occur with the simpler menus, means 'Windows XP style' deactivated in Options.
2nd. closes
—> pic_viewer
:) Hello !
• I can't reproduce that issue either.
- Here, if I click a second time on the same open menu, it closes, that's the normal behaviour in Windows.
- A third click reopens the menu, as it should…
• Just “In the case“, please verify if you have a file <xnview.exe.manifest> - 640 bytes -
set in the folder of XnView (in the root, not in any sub-folder)…
- XP-Pro - SP1 - French-English
XnView 1.91.6
:mrgreen: VG
