1.96.1: Crash deleting a hidden file
zencd
Post by zencd »
1) Let there be at least two image files: one hidden and one normal
2) Open the hidden one with xnview
3) delete it with DEL button
4) the program crashes:
XnView for Windows has encountered a problem and needs to close. We are sorry for the inconvenience.
AppName: xnview.exe AppVer: 1.91.0.0 ModName: xnview.exe
ModVer: 1.91.0.0 Offset: 000ae115
Windows XP SP2, XnView 1.96.1
P.S. I'm wondering why "File version" is 1.91.0.0 while Help/About says 1.96.1 ...
Re: Crash deleting a hidden file (1.96.1)
XnView is started in edit mode or in fullscreen?
Which OS?
zencd
Post by zencd »
XnView is started NONfullscreen mode ("edit mode" as I understand)
OS is Windows XP SP2
No bug here
:arrow: zencd
:) Hello !
• I cannot reproduce that issue. I tested a hidden file with which I started XnView in Total Commander
via D&D on its icon, so in normal “View”.
- I tested too from the browser >> Select its thumbnail >> Remove, no problem, no crash.
- In both cases, the hidden file is deleted.
- In “View”, I get the next file displayed (I have set this option).
- Win XP-Pro SP1 - XnView 1.91.6
:mrgreen: KR
ckit
Post by ckit »
I can't reproduce the crash either.
Are you using Delete to the Recycle Bin or not?
Clean Bin !
—> ckit
:) Hi Chris !
• Personally, I delete directly, my Recycle Bin is always as so empty as a politician's speach ! Image
:mrgreen: KR
zencd wrote:XnView is started NONfullscreen mode ("edit mode" as I understand)
Could you try to disabled option/view/misc/Read ahead?
Ticked---
:arrow: Pierre
:) Hello !
Could you try to disable option/view/misc/Read ahead?
• That box IS ticked here, it doesn't cause any crash (and also I delete directly, not to the Recycle Bin)…
:mrgreen: KR
zencd
Post by zencd »
This matters! I disabled "read ahead" and the crash has gone.
P.S. I delete files via Recycle Bin
And you have only 2 files in the folder?? No hidden files?
zencd
Post by zencd »
The files remains the same: they are two within the folder: one hidden and one normal.
