No thumbnail with NEF files
TD
Post by TD »
The thumbnails of NEf files made by my camera are displayed correctly. But when I open a JPEG file with Nikon Capture NX and save it as a NEF. I see no thumbnail in the browser view and only a very small picture in the preview on my second monitor.
Other software displays the same file correctly.
Re: No thumbnail with NEF files
TD wrote:The thumbnails of NEf files made by my camera are displayed correctly. But when I open a JPEG file with Nikon Capture NX and save it as a NEF. I see no thumbnail in the browser view and only a very small picture in the preview on my second monitor.
You can see the thumbnaisl because XnView can extract the thumbnail, but can't read the picture
TD
Post by TD »
The problem is that I do not see a thumbnail in the browser and only a very small thumbnail in the preview.
TD
Post by TD »
Have to bring this up again because it is very anoying to have no thumbs in the browser view.
I understand, that XnView cannot read the picture, sad..., but ok. But why there is not thumbnail in the browser view?
I don'understand.
TD wrote:Have to bring this up again because it is very anoying to have no thumbs in the browser view.
I don'understand.
If you don't have 'recognise only by extension', xnview try to build thumbnail from the file by reading the header. The header for RAW file is similar to a TIF.
TD
Post by TD »
But I have 'recognise only by extension' and all my NEF files are perfectly displayed.
Only the NEF's that I made by opening a JPEG file with Nikon Capture NX and saving it as a NEF make the problems.
If you want, I can sent you such a file, just tell me where to sent it.
TD wrote:But I have 'recognise only by extension' and all my NEF files are perfectly displayed.
Yes, please webmaster at xnview dot com
scw2wi
Post by scw2wi »
If you save JPEG pictures as NEF file,
this is complete different for a NEF RAW-File.
It is a JPEG file with edit steps saved in a NEF format.
Walter
Walter
PSHRutPark
Post by PSHRutPark »
If I understand your problem and your current settings correctly, I suggest you try turning OFF the "recognise only by extension" option and rebuild the thumbnails.
You may be pleasantly surprised!
PETER
