Extracting embedded jpgs from NEF files in batch
PSHRutPark
Post by PSHRutPark »
Pierre,
This is a copy of a discussion I have been having on the Nikonians Forum:
">That is true, Peter, but there is a difference between
>reading and extracting. PM will quickly extract, in a batch
>operation, the embedded JPG from one or more NEFs (including
>any Capture edits of course), and generate JPG files. If I
>have 100 or 1000 NEFs that I want to extract, PM does it
>very quickly and effectively. This feature allowed me to
>abandon the preservation of JPG preview files for quick
>access to the images, slide shows, etc.
>The universe of apps that will do that extraction (verses
>simply reading the embedded jpg while browsing) is much
>smaller. iMatch will do the same thing, but it is not a
>browser, it is a cataloging app, which I think is a
>different beast. I'm sure there are others that can do that
>extract but it is important to make this distinction.
>Neil
Yes, Xnview doesn't currently extract the embedded jpeg (with edits) in a batch process. In its sophisticated batch options it will extract the original raw image and save as jpeg (or in many other formats) according to a number of quality and/or "speed" options.
Since Xnview has the option to preview and/or display NEF raw image or the embedded jpeg (with Capture NX edits) it seems that it could be implemented quite easily. To this end I might suggest it to the author. "
("PM" referred to above is PhotoMechanic)
So ... would the batch extraction of the jpgs embedded in NEFs be relatively easy to implement?
Merely curious.
PETER
