Same xnview.ini for versions 1.91 and 1.80?
Peter2
Post by Peter2 »
I use the current version of Xnview (1.91.5), other colleagues Version 1.80.
I want to transmit my configuration to other PCs - is it possible to use my 1.91-ini in a 1.80 version? Or is is necessary to configure the old version by config-menu?
Peter
Avoid !
:arrow: Peter2
:) Hello !
I use the current version of Xnview (1.91.5), …
• The newest current version is 1.91.6…
… is it possible to use my 1.91-ini in a 1.80 version? Or is is necessary to configure the old version by config-menu?
• I think that you might not attempt to do so.
A mountain of entries have been added¦changed since the 1.8… versions which indeed don't support them.
- Hence, you can only tweak the INIs of 1.80 to match yours from the Options or by hand,
but only for the items which existed already (and have not been changed).
:mrgreen: KR
Note : BTW, why your colleagues don't upgrade their “XnView” ?
Peter2
Post by Peter2 »
Thank you
I suspected it will not work ..
Peter
Clo wrote:Note : BTW, why your colleagues don't upgrade their “XnView” ?
Because they use the (old) software package of our company and I use new software ..
Re: Same xnview.ini for versions 1.91 and 1.80?
Peter2 wrote:I use the current version of Xnview (1.91.5), other colleagues Version 1.80.
You can try, not all settings will be used for 1.80
Peter2
Post by Peter2 »
xnview wrote: You can try, not all settings will be used for 1.80
So you mean that the old program will take the unchanged functions (settings) and will ignore the new ones?
Peter
yes
