Change Timestamp: EXIF->File Date for Canon CR2 files
willyl
Post by willyl »
I understand I cannot modify the EXIF info in a RAW file but I simply want to modify the file date/time to the EXIF data. When I do this I only get the time from the EXIF not the date.
Also, the EXIF time it might set the file date/time to is wrong. Not certain where it is getting it from.
Not certain if this is a bug, by design, or because I am doing something wrong.
Thanks!
Bill
Re: Chage Timestamp: EXIF -> File Date for Canon CR2 file
willyl wrote:I understand I cannot modify the EXIF info in a RAW file but I simply want to modify the file date/time to the EXIF data. When I do this I only get the time from the EXIF not the date.
Sorry but i don't udenrstand. Where do you have only the time? You want to chage EXIF date or file date?
willyl
Post by willyl »
It is a Canon RAW CR2 file with a bad File date on the Windows system. I want to pull the "Date Taken" from the EXIF and redate the file on the file system.
I had to restore files from a backup and all the file dates got set to the restore date.
willyl wrote:It is a Canon RAW CR2 file with a bad File date on the Windows system. I want to pull the "Date Taken" from the EXIF and redate the file on the file system.
Could you send me the file?
