Adjust only selected part of image
blued
Post by blued »
Maybe I am asking too much since this is a free program and its already packed with so many features, but I'll ask:
Is it possible to adjust only the selected part of an image, ie, hue, saturation, brightness, contrast, level, etc? At present the above adjustments affect the whole picture, not the selected part. :D
Thanks so much,
b.
Re: Adjust only selected part of image
blued wrote:Hi,
Thanks so much,
b.
If you select a rectangle in the picture, only this area is adjusted
blued
Post by blued »
My apology, you are right it works. I think I tried it before and it didnt work, dont know why.. but at least it works now. Thanks.
b.
blued wrote:My apology, you are right it works. I think I tried it before and it didnt work, dont know why.. but at least it works now. Thanks.
b.
In the preview in the dialogs the effects/filters are applied on the whole image, but when confirming the dialog or using "Apply to image" the effects/filters are applied to the selected area, only. Maybe this has confused you... ...it has confused me a bit. ;-)
oops66
splines to selected a complex part of image
Post by oops66 »
Maybe is it the mature time for Xnview to allow the ability to sketch splines to selected a complex part of image, for filters (blur, ie, hue, saturation, brightness, contrast, level, etc...)?
Because this step is not too big now from this 1.92 version !
