1.92: Blp-file problem
Kthana
Post by Kthana »
Some blp-files are not displayed correctly.
Here is an example of the problem:
On the left is how Xnview shows it and on the right is how it should be shown.
The blp-file in question can be found here: http://www.wormzone.net/img/Ability_Seal.blp
The problem seems to be that the alpha information for DXT5-type blp's are parsed the same way as the alpha information for DXT3-types.
For information about the differences between those 2, check http://en.wikipedia.org/wiki/S3TC.
Not better…
:arrow: Kthana
:) Hello !
• I tested your sample in two ways like shown below; at left,
with Use Alpha Channel ON (the chequered pattern is set), at right it's OFF :
• Indeed, it's not a wonder, your baby-seal is visible…but not better than your own image :|
:mrgreen: KR
Kthana
Post by Kthana »
It doesn't surprise me that you can't see the problem with the alpha channel if you set xnview to not use the alpha channel :wink: .
Both
:arrow: Kthana
:) Hello !
• Did you read that I wrote above ? The image at left is WITH A-channel, and indeed, that doesn't work.
• At right, it's WITHOUT A-channel here.
- I set A-channel ON usually, I just disabled it to test your image. :P
:mrgreen: KR
