File Change Confirm Window needed
rfrank
Post by rfrank »
Hi all.
This is my first post and i would like to thank Pierre for his excellent program.
I've found that if you modify an image (rotating it, changing brightness, contrast or similar), it keeps the changes automatically and Xnview doesn't display a "Do you wish to save the changes?" Window when you go and see any other image.
This is a little annoying since i'm the type of person that rotates images a lot just to see "how would it look" and then switch to another image.
Is it possible that you could make a window that asks for "Saving File Changes"????
Thanks for reading this post!!!!
P.D. version 1.92.1 Actually SHOWS that window, but it keeps the image rotated until you close and reopen Xnview
marsh
Post by marsh »
The program will begin to save changes automatically if you answer "Yes + [x]Never Show again" in the question dialog. You should see the dialog box again after restarting program.
Changing these settings are discussed in topic: How to make xnview never ask about saving?.
