crashing when viewing .ai files
I have all my Illustrator files in one folder and when I try to view them XnView crashes.
Anyone have any ideas please?
Eugenia
Eugenia
Which…Which… ?
• I've a few *.ai files here to test - under Win Xp-Pro SPI - XnView 1.92.1.
- The file v. 3 is not recognized…
- The files v.8 work OK, no crash. This in "View" mode and in the "Browser" mode as well …
- Please, tell us a bit more about which *.ai version your files are, the XnView and Windows versions you are running.
- There is another thread too (at least) about *.ai files, please use the Search…
Thanks for the quick response - I did try a search for illustrator files but no luck - I will try again
Anyway... I am using XP home sp1 and all my files were created in Illustrator CS2 - the same folder contains .eps files version 8 (as per stock site requirements).
It appears there is something amiss in my set up if you are not having problems
I *can* use bridge but XN View is SOOOOO convenient!
Eugenia
Eugenia
Options to check
• You could check your options for :
1. General - Operations >> [×] Display all image file-types (ticked here).
2. Options - Browser - File List >>
AI, PS, PDF [×] [×] [×] … Tick the needed boxes, according to your usual workflow…
- Forum Librarian
Search results for “ai AND ghostscript”:
- Cannot open AI file
- FAQ: How to display vector formats like PDF, AI,...? GhostScript!
- AFPL ghostscript not found on your system is annoying!
- Thumbnail AI
- contactsheet from eps and ai
- AI to JPG, nconvert , cant read file (gs installed)
- Illustrator AI support with Version 1.82.4
- "AFPL ghostscript was not found on your system"
- AI files
- PDF : les afficher dans XnView ? [RÉSOLU] (fr2en)
- GhostScript - pdf graphic files
- XnView and Ghostscript
Hi its a bit hard to send the whole folder - that is what crashes as the thumbnails are loading - this is the error detail:xnview wrote:Could you send me a sample that crash xnview?Anonymous wrote:Thanks Xntriq - I have the latest Ghostscript and my problem is not that they will not open - they do, but as the pictures are loading xnview crashes.
It's very annoying!
AppName: xnview.exe AppVer: 1.92.0.0 ModName: gsdll32.dll
ModVer: 0.0.0.0 Offset: 000aaad4
Does that sound like a ghost script problem?
One by one…
•The defect is indeed in that DLL which belongs to GS alright.
- I've two GSs here, and old 8.13 (no more used) where that item is 2.4 MiB, and a newer 8.53 (used) where it's 3 MiB.
• You could try that trick :…its a bit hard to send the whole folder…
- In a (good) file manager, move your files one by one into a test_temp dir you have to create.
After the first file has been moved, try to open the original folder in XnView.
- If a crash occurs, move the second file and try again… and so on, till there is no more crash.
Obviously, the faulty file shall be the last moved - supposing that only one file is the culprit.
- According to the Murphy's Law*, generally it's the very last file !
- If you have a mountain of *.ai in the original folder, you could attempt also
to dispatch them into several test_temp dirs, then process as above, but partial folder by partial folder, that saves time…
Good luck !
*Also so-called “Rule of the worst case” or “Law of the coffee spoon”
• Or else, pack the whole folder as RAR or so, if not too huge as an archive, you could send it to Pierre (maybe).
Re: One by one…
Oh Wow I just never thoought it was one teeny file causing all the problems.
I found the offender, zapped it and lo, the world brightened.
Thanks for the good advice _ I am EVER so grateful!!
Eugenia (much relieved)[/u][/i]
Troken
Troken
Latest 8.61 (I think it is the version). However I have reinstalled GhostScript, and will check if the crashes reappear.xnview wrote:Could you send me some sample? Do you have the AFPL or GPL version?Troken wrote:I will try also, my XnView crashes several times every day when trying to create thumbs for .AI or .PDF files. Very annoying, and it seems to have happened after 1.92.1...
