Borderline around any image in Xnview - shud be so easy
budz45
Post by budz45 »
Hi guys,
Display Borderline in Xnview
The default Windows Picture and Fax viewer - automatcially has this
can you see the thin black borderline around the image in Win fax viewer? Is this possible as an option to enable in Xnview
Re: Borderline around any image in Xnview - shud be so easy
budz45 wrote:Hi guys,
Yes, easy. An user ask me to be able to have a spacing around the image too
I support this request.
Images look neater with a thin border. But the border should be configurable (colour, on/off).
budz45
Post by budz45 »
Thank you you guys, I hope to see this very small feature added in soon, it just adds a neatness to it.
Xnview is the best image viewer in existence
Thanks for your kind words, budz45. :-)
Your request brought an idea to my mind: Auto background tone
budz45
Post by budz45 »
Apologies for this topic resurrection.... really sorry but was just thinking of this feature again
Im running Xnview 1.961 and also latest mp and would like to see this feature in future in the Options. Would be nice:
budz45
Post by budz45 »
xnview wrote: Yes, easy. An user ask me to be able to have a spacing around the image too
OK, I made a lot of requests recently,
Might this 'borderline around images' make it in time for Xnview MP?
Should be as simple as just a tickbox alongside a colour selector
budz45
Post by budz45 »
Pierre,
You have added this request in Xnview MP 0.25 alpha with colour selector, thank you :) although you need to address the following two:
1. The border line is not displaying properly around any image viewed, please fix
2. Where is the same matching border for top and bottom of image (horizontal), please fix
I have snapped two screenshots the first of Windows XP's default view and second of Xnview MP 0.25 with border enabled for a comparison
(Tree.jpg can be found in Vista's default 'sample pictures')
Image Image
see how the border displays on Win XP's default viewer, this is what it should look like in mp
budz45
Post by budz45 »
budz45 wrote:Pierre,
Image Image
OK this problem is only happening for some images and not all, so I think it's just a small bug that could be addressed in future
Yes right, the first bug is due to this one
