A lot of tagging
A lot of tagging
The menu for tagging (View > Tag) got pretty crowded these days. In 1.92 beta it looks like this:
Tag current
Untag current
Invert
Untag all
Clear all tags
Show tag box
What's the difference between "Untag current" and "Untag all"?
"Clear all tags" will clear all tags - not just the ones in the current folder but all tags ever set. (Makes only sense in combination with the option in Tools > Browser > Thumbnails > Info icons". I think this function should be separated by seperator because this will affect not just the selected.
My suggestion:
Tag
Untag
Invert
Untag all (or "Clear all" or "Reset all" or "Reset all tags" or "Untag overall")
Show tag box
Tag current
Untag current
Invert
Untag all
Clear all tags
Show tag box
My suggestion:
Tag
Untag
Invert
Show tag box
Re: A lot of tagging
'Untag all' untag files from current view, and 'clear all tags' clear for all files
This is clear. But what's the difference between "Untag current" and "Untag all".xnview wrote:'Untag all' untag files from current view, and 'clear all tags' clear for all files
Dreamer
Untag current file / Untag all tagged files, right Pierre?helmut wrote:But what's the difference between "Untag current" and "Untag all".
For me "Invert" is a bit confusing - there is a similar feature - "Invert selected" - to select all unselected files and unselect all selected, but here "Invert" is just to toggle the current file. Perhaps other term would be better - "Toggle", or "Invert current", or just "Tag/Untag"?
Dreamer
YesDreamer wrote:Untag current file / Untag all tagged files, right Pierre?helmut wrote:But what's the difference between "Untag current" and "Untag all".
pic_viewer
Tag is a temporary category as discussed on some thread...helmut wrote:We have the tags. And now we have a Tag category. That's confusing somehow.xnview wrote:i think that "Clear tag category" is better
I'd rather have something like "Global untag" or "Untag all tagged files (global)".
@pic_viewer: I do like your "global".
I'm not sure that 'Global' is good
Dreamer
Still don't get it:xnview wrote:YesDreamer wrote:Untag current file / Untag all tagged files, right Pierre?helmut wrote:But what's the difference between "Untag current" and "Untag all".
Untag: Untag current file
Untag all: Untag all files
Clear all tags: ???
There's something wrong, missing, or superfluous, I think.
Untag all: Untag all files from current view
Clear all tags: Untag all tagged files (stored in DB)
I see. But I think this is confusing.xnview wrote:Untag: Untag current file
Do we really need "Untag all files from current view"? With "Ctrl+A" and Space key does the same job.
(Actually I noticed that Space key does not set and unset but invert, which is wrong, I think. I'll start a new topic for this).
