Copy speed
neutrino1
Copy speed
Post by neutrino1 »
I used the search function in XnView to find all the images that had a string in the description. It found about 7,500 files. I selected all the files and told XnView to copy all of them to a directory on a different logical drive.
XnView did this VERY, VERY, VERY slowly. It took about one second per file which would not have been too bad if it had a Skip All button.
Is this a normal speed for XnView?
Re: Copy speed
neutrino1 wrote:Is this a normal speed for XnView?
No, which OS? Your DB cache is big? Do you have description?
neutrino1
Re: Copy speed
Post by neutrino1 »
No, which OS?
Windows XP Home SP2
xnview wrote:Your DB cache is big? Do you have description?
I do not know what you mean by DB cache. All the files have descriptions.
Re: Copy speed
Option/Thumbnail/Cache
And description from descript.ion file?
neutrino1
Re: Copy speed
Post by neutrino1 »
I did have the Option/Thumbnail/Cache turned on. There are four cache files. The largest one is 3,390,523 bytes.
The largest descript.ion files I have now is 187 K but it was probably at least 40 K smaller when I copied the files.
Re: Copy speed
neutrino1 wrote: The largest descript.ion files I have now is 187 K but it was probably at least 40 K smaller when I copied the files.
Your files are all in the same folder?
Could you try to copy but rename the descript.ion file before?
neutrino1
Re: Copy speed
Post by neutrino1 »
The files are in several different folders. That is why I used the Search function.
Is it safe to rename descript.ion files. I suppose I could rename all the description files but there are more than 140 of them. Only 17 of the description files are over 10 K in size and only three of them are over 100 K. Can I rename just the larger ones? If so, what size limit should I use?
Can I use the search function to find the files that have the description I want and then rename the description file? Obviously, if I rename the description file first, I will not be able to find the files.
Re: Copy speed
It's a test to find where is the problem.
Is it possible to create a copy of you root folder, delete in it all descriptions, and try to make the copy by xnview? (i would like ot know if the problem is description)
neutrino1
Re: Copy speed
Post by neutrino1 »
xnview wrote:
neutrino1 wrote:
xnview wrote: Your files are all in the same folder?
I created a directory with 8,002 jpeg files without descriptions (1.1 GB) on my logical E: drive. I copied all the files to a directory on my logical D: drive. It took 16:22 with XnView.
I copied the files again with ACDSee 2.42 and it took 07:59. I realized that the difference might be because of the Windows cache so I copied the files again with XnView and it took 12:32 with XnView.
I created a directory with 8,194 jpeg files (3,243 with descriptions) (1.1 GB) on my logical E: drive. I copied all the files to a directory on my logical D: drive. This time I copied the files with ACDSee first. It took 08:29 with ACDSee.
I copied the files again with XnView and it took 46:15.
Re: Copy speed
neutrino1 wrote: I created a directory with 8,194 jpeg files (3,243 with descriptions) (1.1 GB) on my logical E: drive. I copied all the files to a directory on my logical D: drive. This time I copied the files with ACDSee first. It took 08:29 with ACDSee.
Ok, so the problem seems to be the description :-(
Could you send me your email by PM, i would like to send you a test version?
Re: Copy speed
Do you have received it?
neutrino1
Re: Copy speed
Post by neutrino1 »
xnview wrote:Do you have received it?
I apologize for taking so long to respond. I have been more ill than usual.
Yes I received it and it is MUCH faster than the other version. I think it is about ten times as fast.
Do you want me to time it exactly?
Re: Copy speed
No exact time is not needed. Thank you for testing and your reply!
