Unicode data in Exif UserComment looks a little bit weired
Pbaumann
Post by Pbaumann »
if unicode (utf-16) is used in the EXIF:UserComment field, XNviews(193B2) output looks a litte bit strange. Each char is follwed by a gap which looks like a space.
Best wishes
Paul Baumann
Re: Unicode data in Exif UserComment looks a little bit weir
Pbaumann wrote:Hi,
Best wishes
Paul Baumann
Could you send me a sample?
Pbaumann
Post by Pbaumann »
picture:
Exifdata with gaps:
best wishes
Paul
Yes i have it, but don't know if unicode EXIF comment is in the standard
Pbaumann
Post by Pbaumann »
Unicode is part of the standard!
Take a look at http://www.exif.org/Exif2-2.PDF On Page 28 you can find the specification of the Exif UserComment field.
Possible character codes are ASCII,JIS,UNICODE and "Undefined".
Best wishes
Paul
