Request: new renaming function: ignore character
surfacecleanerz
Post by surfacecleanerz »
It would be very great, if XNView would get a new function for renaming files: Let me explain it with an example. I have files "DSCN12000 picture.jpg" - "DSCN12001 Foto.jpg". And now iI want to rename them to "1 picture.jpg" - "2 Foto.jpg". I think this is impossible with the functions implemented, yet. The second part of the filename should be untouched, only the first part should be converted. A problem is, that the second part is of variable length, because I use it for tagging the pictures with what is shown on them.
Thanks for that great software!
regards,
Stefan
Re: Request: new renaming function: ignore character
surfacecleanerz wrote: It would be very great, if XNView would get a new function for renaming files: Let me explain it with an example. I have files "DSCN12000 picture.jpg" - "DSCN12001 Foto.jpg". And now iI want to rename them to "1 picture.jpg" - "2 Foto.jpg". I think this is impossible with the functions implemented, yet. The second part of the filename should be untouched, only the first part should be converted. A problem is, that the second part is of variable length, because I use it for tagging the pictures with what is shown on them.
Ok, not so easy :-)
surfacecleanerz
You're right not so easy, but possible I think.
The first part has always the same length. So it should be possible to exchange it.
No i have to drive to CeBit...
regards,
Stefan
Enmoku
Post by Enmoku »
RegExp (PCRE) would work here, but it's not exactly the easy to use for the end user :)
A nightmare---
:arrow: Enmoku
:) Hello !
• OMG ! Right ! Paul “Ouistiti”-friend and I have translated the PCRE doc into French for a help folder in a soft we deal with,
it was a fortnight-job and a real nightmare.
- Moreover, that library is very powerful, but not gratis… :(
:mrgreen: KR
surfacecleanerz
Can you describe what you mean?
Sounds interesting (ok not the french version ;-)
regards,
Stefan
Mirror site
:arrow: surfacecleanerz
:) Hello !
• We found out a mirror site which has the whole original PCRE docs HERE in English.
- Some original pages @ Cambrige University have been moved¦renamed¦deleted,
hence it was impossible to follow the original links…
…ok not the french version ;)
- It's a pity, because the French version for that soft is BEAUTIFUL :D See :  “Expressions régulières”…
:mrgreen: VG
surfacecleanerz
Thank you!
I don't speak french, that's the problem and I forgot much of my latin and spanish is often different...
regards,
Stefan
