Thanks for the batch watermarking
But I think there is a bug... when I set it up for:
Bottom right with 10 Horizontal and 10 vertical it still places it at the absolute bottom and absolute right with no padding.
On another note:
So I thought I would make the same tranparent gif but just add 10 x 10 more tranparent till this could be fixed. That didn't work, it made all the tranparent white. It only does this with the batch watermarking...
So for now I'm still watermarking 1 at a tme.
Anyhow thanks for and incredible /free product...
Batch watermark
Re: Batch watermark
I think that you must use -10,-10 as offsetlimer wrote: But I think there is a bug... when I set it up for:
Re: Batch watermark
negative , Positive , -10 , -19999 , +10 + 1,557I think that you must use -10,-10 as offset
It doesen't matter... it always just goes to the absolute bottom right with out any padding
it ignores any padding setting ...
Re: Batch watermark
I have not the problem, is it the last version?Anonymous wrote:negative , Positive , -10 , -19999 , +10 + 1,557I think that you must use -10,-10 as offset
