3dsmax thumbnails
RGhost
3dsmax thumbnails
Post by RGhost »
:bug: .max (any version of 3dsmax) 3dsmax's thumbnails doesn't preview and doesn't show, since ~1.91 (if I remember correctly)
Can it be fixed?
p.s. Tnx for great viewer! :D
Royal Ghost | http://veda3d.com
Re: 3dsmax thumbnails
RGhost wrote::bug: .max (any version of 3dsmax) 3dsmax's thumbnails doesn't preview and doesn't show, since ~1.91 (if I remember correctly)
Can it be fixed?
Do you have the Xcompound.dll plugin?
RGhost
Post by RGhost »
Yes I have. I've just cheked it.
07.12.2006  18:35            61 440 Xcompound.dll
Now I'm using 1.93.4 - full.
could you send me a .max file?
RGhost
Post by RGhost »
In this archive 3 max files saved by different 3dsmax with simple teapot object in scene.
http://veda3d.com/img/maxfiles_4xnview.rar
RGhost wrote:In this archive 3 max files saved by different 3dsmax with simple teapot object in scene.
I have the thumbnails for these files, do you have the last version of xnview and xcompound?
RGhost
Post by RGhost »
I reseted xnview.ini for sure, nothing happened. Instead of thumbnails form .max files I see white thumbnails.
I'm not sure that it can prevent to show thumbnail:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.max\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
@="{9DBD2C50-62AD-11d0-B806-00C04FD706EC}"
This registry 3d-party modification allows Explorer to show properly .max thumbnail.
Crash !
:arrow: Pierre
:) Hello !
• I've nine *.max samples here in a folder.
- Testing them with 1.93.4, I get some thumb nails (3…4), but waiting for a ten of seconds,
XnView crashes, and Dear Bill comes to close… :(
:mrgreen: KR
ouistiti
Post by ouistiti »
I confirm the crash with the Clo's *.max files… :(
Paul
1,77245385090552... •
Tea pot OK
:arrow: Pierre
:) Again…
• The RGhost's files work fine here, I've the thumb nails and no crash…
• However, it's abnormal to get a crash with my own samples, do you wish to get them ?
:mrgreen: KR
Re: Tea pot OK
Clo wrote: • However, it's abnormal to get a crash with my own samples, do you wish to get them ?
Yes please
RGhost
Post by RGhost »
Hm. I install older 1.91 full, it shows (rebuild) thumbnails .max. 1.93.4 not shows.
I don't remember for sure what kind of version xnview stoped to show .max thumbnails.
ouistiti
Post by ouistiti »
:arrow: RGhost
Try CTRL +H (Toggle the Alpha Channel use)
Here it works perfectly now !
Friendly
Paul
Samples are sent
:arrow: Pierre
:) Hello !
• I've sent my bunch of *.max files among which one crashes the programme.
:mrgreen: KR
RGhost wrote:Hm. I install older 1.91 full, it shows (rebuild) thumbnails .max. 1.93.4 not shows.
I have no problem with 1.93.4
