first I'd like to thank you for your great work! I use Xnview since some years and it's just fast and easy.
But since some time, I got a strange problem: When I doubleclick an image in Windows Explorer or TotalCommander, Xnview opens the first image of the folder in fullscreen mode. This is a bit anoying, when there are 50 photos in one folder...
How can I change this?
Yours,
Matthias
Opening files from Windows Explorer or TotalCommander
- Forum Librarian
Do you have check:
http://newsgroup.xnview.com/viewtopic.php?t=14795
guest09999
Re: Opening files from Windows Explorer or TotalCommander
helloMatthias wrote:Hi,
Yours,
Matthias
the same problem for me. I'm using w2k sp4 and xnview 1.94
Mode when starting with a file is[ Normal ]
best reg
fritz
And no problem if you drag&drop a file on xnview's icon?
