Large Panoramas cause turned images and wrong thumbnail view
Micha
Post by Micha »
larges images from
http://www.flickr.com/photos/tags/equirectangular/
show the following effects
The little preview images show a part of the image only and the large preview is turned. If I drag&drop the image to photoshop, it is turned too. But if I open it in my render software, it is shown right like at the web side here (this image show this effect)
http://www.flickr.com/photos/gadl/2446425482/sizes/o/
At the moment it is very difficult to browse for this images per XnView. Maybe it can be fixed. Good luck.
Best regards,
Micha
Your images are rotated automatically by XnView, which is indicated by the small info icon next to the appropriate thumbnails.
FAQ How to rotate images automatically and its trouble-shooting section should solve your "problem".
Micha
Post by Micha »
Thank you - now it works. :D
