Accessing "Image Number" in EXIF data for rename
Post by Guest »
I love this program!!!
The batch rename has many fields you can insert into the new name, but I can't find a field to capture the "Image Number" which exists in all Canon EXIF data. Properties on the image I see:
Camera Manufacturer : Canon
Camera Model : Canon PowerShot S30
Orientation : top-left (1)
X Resolution : 180
Y Resolution : 180
Resolution unit : Inch
Date modified : 2008:04:30 21:49:00
YCbCr Positioning : centered (1)
<snip>
White balance : Sunny
Sequence number : 0
Picture info : IMG:PowerShot S30 JPEG
Firmware version : Firmware Version 1.10
Image number : 398-9821
Compression : 6
X Resolution : 180
Y Resolution : 180
Thumbnail offset : 2036
Thumbnail length : 5779
Any ideas how to do that?[/b]
Re: Accessing "Image Number" in EXIF data for rena
Anonymous wrote: Image number : 398-9821
Is it in Makernotes?
stormy1777
Post by stormy1777 »
I also see this issue. I can not find "Makernotes" under EXIF-Image section. By the way, that section should be sorted since it's a long list.
I searched in all other sections and can not find that image-number or the makernotes you suggest.
I have a sample image if you want I can email to you.
stormy1777 wrote:I have a sample image if you want I can email to you.
Yes please
stormy1777
sent via email
stormy1777 wrote:sent via email
on xnview dot com?
stormy1777
Sorry! I looked at profile and sent to wanadoo.fr, now I resent to xnview email (contact@)
stormy1777
--- Pierre-e Gougelet </wrote> Ok, this image number is in Makernotes, currently there is no way to use
> Makernotes. I must add it
great!!! can't wait :)
stormy1777
Re: Accessing "Image Number" in EXIF data for rename
Did it make it into 1.96? I can't find it.
stormy1777 wrote:Did it make it into 1.96? I can't find it.
Not yet
stormy1777
rzyz
Post by rzyz »
Is it possible now?
Because, i can't do it on the last version.
Found this thread from google;)
